Autore Cosmo SkyMed 4, si completa il più importante progetto satellitare italiano  (Letto 4444 volte)
Dalla base di Vandenberg in California, la ULA (United Launch Alliance) lancerà venerdì notte (ore 7:20:05 p.m. PDT = ore 3:20:05 italiane di sabato mattina) un razzo Delta-II che trasporta il satellite italiano COSMO-SkyMed4. La finestra di lancio rimarrà aperta per 1 solo secondo!  :swoon:
Qui si potranno seguire gli eventi in forma di blog in diretta + stream video
SpaceflightNow blog
ULA webcast
ULA stream video
INFO
Agenzia Spaziale Italiana
Forum Astronautico
Sole 24 ore
ULA - Dettagli sul razzo
Foto del Delta-II, pronto sulla rampa di lancio
Ora locale - Los Angeles, California
Motivi del ritardo nel lancio, inizialmente previsto per il 29 ottobre:
(fonte: Spaceflightnow.com)
Rocket-maker United Launch Alliance says the Delta 2 will take another shot at launching Tuesday evening. Tonight's scrub was called for a nitrogen purge problem in the vehicle's aft engine section.
"During the terminal launch countdown Monday, mission managers noted an insufficient flow of gaseous nitrogen in the Delta 2 engine compartment. Gaseous nitrogen is used to ensure that critical components in close proximity to cryogenic propulsion systems are kept warm," ULA's press statement reads.
"To allow engineers the time required to correct this issue, the launch attempt is delayed 24 hours."
The Delta 2 rocket carrying Italy's COSMO-SkyMed 4 spacecraft is scheduled for launch tonight at 7:20 p.m. PDT (10:20 p.m. EDT) from Vandenberg Air Force Base, California.
The ideal weather will continue along the Central Coast, giving a 100 percent chance of acceptable conditions for tonight's launch, Air Force meteorologists say.
The launch time outlook includes clear skies, unrestricted visibility, northwesterly winds of 8 to 12 knots and a temperature between 61 and 66 degrees F. Winds aloft will max at 38,000 feet from the south-southeast at just 35 knots, the forecast says.
« Ultima modifica: 09 Nov 2010, 23:29:29 da Ripley »
Purtroppo, a causa delle trasmissioni televisive nazionali sulle "elezioni di medio termine" in atto in questo momento negli U.S.A., stanotte non potrà esserci la copertura in diretta streaming dell'evento...
 :mda:
« Ultima modifica: 04 Nov 2010, 12:21:17 da Ripley »
"Cosmo SkyMed non è partito: lancio rinviato per la quarta volta.
A meno di un minuto dal lancio sono scattati due allarmi e le cause sono riconducibili a un problema di insufficienza di batteria del lanciatore Delta I.
Il lancio del satellite italiano SkyMed, dalla base californiana di Vandenberg, è stato dunque rinviato e probabilmente avverrà nella notte tra venerdì e sabato.
Questo lancio (quando avverrà...) segnerà il coronamento di un programma spaziale italiano da oltre un miliardo di Euro che permette di riprendere immagini della Terra in qualsiasi condizione di visibilità. Il satellite è infatti in grado di riprendere immagini del nostro pianeta in qualsiasi condizione atmosferica e notturna.
L'intera costellazione, compreso il sistema per la gestione dei dati, è stata progettata e costruita in Italia dalle aziende della Finmeccanica Thales Alenia Space, Telespazio e Selex Galileo.
Questa è la terza volta che il lancio fallisce. La prima è stato lo scorso 29 ottobre, a causa di un problema al sistema esterno. La seconda invece nella giornata di ieri per un inconveniente tecnico ricondotto all'interruttore del riscaldatore serbatoio di ossigeno liquido e questa volta a solo un minuto dalla partenza."
Per chi si chiedesse come vengono usati questi satelliti...
Giusto per mettere un punto a questo thread mancava solo questo.
Anche i satelliti Cosmo-SkyMed italiani sono in campo nell'operazione 'Odyssey Dawn' sulla Libia.
Link ADNKronos
« Ultima modifica: 04 Apr 2011, 14:45:25 da Ripley »
Da ASI.it:
COSMO-SkyMed fotografa in Pakistan 'l'isola che non c'era'
La costellazione italiana ha prodotto le prime immagini radar del lembo di terra affiorato nel Mar d'Arabia in seguito al sisma del 24 settembre
30 Set 2013 - Arrivano dai satelliti italiani della costellazione COSMO-SkyMed le prime immagini radar della nuova isola affiorata in superficie al largo della costa di Gwadar, nel Mar d’Arabia, in seguito al sisma di magnitudo 7.7 che ha colpito il Pakistan lo scorso 24 settembre.
...continua...
http://www.asi.it/files/Lungo_Costa_ed_Isola_2_metri_di_risoluzione_sito.jpg
http://www.asi.it/files/imagecache/news_image/images/isoletta_max_risoluzione_sito.jpg
