Autore Lancio Soyuz-U - Progress M-15M  (Letto 2800 volte)
« il: 19 Apr 2012, 16:26:28 »
Soyuz-U.jpgLancio Soyuz-U - Progress M-15M
rkk-energia-logo.pngLancio Soyuz-U - Progress M-15M
Dal cosmodromo di Baikonur parte domani, venerdi 20 aprile 2012, alle ore 14:50 (ora italiana) un razzo Soyuz-U con un cargo Progress pieno di rifornimenti per gli astronauti a bordo della ISS.
Questa è la lista della spesa (2,3 tonnellate):
Refueling system propellants amount     648 kg
* Oxygen                                 19 kg
* Oxygen                                 28 kg
Water in Rodnik ("Creek") system tanks  420 kg
Pressured section cargo (total mass 1241 kg)
Equpiment for systems:
* SOGS atmosphere composition control    47 kg
* SVO water supply control               34 kg
* SOTR heat exchange conrtol             20 kg
* SUBA onboard equipment control         21 kg
* SEP electric supply control             4 kg
* SBI onboard measurements control        2 kg
* BITS2-12 telemetry                     16 kg
STOR maintenance and repair items         3 kg
SGO Hygiene and sanitation items        114 kg
SIZ Individual protection                60 kg
Food rations, fresh products            344 kg
Medical equipment, underwear,
personal hygiene and care, station
air purity checking and cleaning        142 kg
FGB Zarya equipment                     179 kg
MRM-1 Rassvet equipment                  41 kg
DC-1 Pirs equipment                       1 kg
Scientific equipment for experiments "Tipologiya",
"Poligen","Bioemulsiya","BIF","ARIL",
"OChB","Plasma Crystal 3-Plus",
"Phyzika-Obrazovaniye"                    9 kg
Onboard documentation, crew parcel,
video and photo equipment                29 kg
A special delivery for Russian
crewmembers                             137 kg
American food rations delivery           38 kg
Total cargo mass                       2356 kg
Il Progress attraccherà automaticamente al modulo PIRS, lasciato libero dal Progress M-14M che ha lasciato la ISS giusto stamattina.
Il lancio e le fasi successive saranno visibili in diretta sui soliti canali.
Countdown su TimeAndDate.com
Countdown su Orbiter Forum
- Le fasi di carico del Progress
- Rollout ed erezione del razzo (fate poche battute!) sul pad di lancio
Fonti: Orbiter Forum - Spaceflightnow launch schedule
« Ultima modifica: 02 Dic 2016, 11:36:44 da LG965 »
Re: Lancio Soyuz-U - Progress M-15M
« Risposta #1 il: 20 Apr 2012, 15:44:25 »
Lancio OK! Ecco il video.
Le cose iniziano a farsi interessanti intorno al minuto 4:30.
Countdown al docking (su OF)
Countdown al docking (su TimeAndDate.com)
« Risposta #2 il: 22 Apr 2012, 21:03:46 »
Procedura automatica di docking avvenuta in orario!
Qui il time-lapse dello stesso filmato.
È interessante notare come a questa velocità sia evidenziata l'imperfezione della manovra, con continui scostamenti e correzioni.
http://spaceflightnow.com/station/exp30/120422prog47pdock/
« Risposta #3 il: 31 Lug 2012, 14:54:35 »
Il cargo Progress M-15M (come già anticipato qua) ha effettuato il 23 luglio la manovra di allontanamento dalla ISS, ma il successivo tentativo di attracco guidato dalla nuova antenna è fallito, ed è stato abortito mentre il Progress M-15M era ancora a 161 km dalla ISS.
L'antenna tradizionalmente usata finora è stata la "Kurs-A".
La nuova antenna testata in quest'ultimo docking è denominata "Kurs-NA".
Questa nuova antenna consuma meno energia, inoltre concentra in una sola antenna le funzioni svolte dalle 5 antenne che compongono il sistema "Kurs-A". La rimozione di queste 4 ridondanti antenne dai futuri veicoli Progress e Soyuz ridurrà il rischio di attracchi abortiti in quanto le 4 antenne in oggetto vengono aperte dopo il lancio ma devono essere retratte prima dell'attracco perchè sono posizionate anteriormente sull'interfaccia di attracco.
Un secondo tentativo di attracco il 28 luglio è invece andato a buon fine.
La causa del fallimento del primo tentativo è stata identificata nella eccessivamente bassa temperatura del cargo. Gli ingengeri hanno quindi attivato tutte le fonti di calore di bordo possibili, portando la temperatura del Progress a 22°C.
Ieri il Progress M-15M ha definitivamente mollato gli ormeggi.
Prima di deorbitare ed andarsi a disintegrare in atmosfera, condurrà due esperimenti, il primo dal 6 al 14 agosto, ed il secondo dal 15 al 20.
Resta così libero lo slot di attracco per il prossimo Progress, in partenza domani.
« Ultima modifica: 31 Lug 2012, 16:40:09 da Ripley »
« Risposta #4 il: 20 Ago 2012, 23:51:54 »
Oggi alle 17:22 il Progress M-15M ha effettuato l'accensione di deorbita, e alle 18:12 i suoi resti sono andati a spiaccicarsi nell'Oceano Pacifico meridionale.
« Ultima modifica: 21 Ago 2012, 12:29:47 da Ripley »
