Autore mission builder help  (Letto 1307 volte)
« il: 05 Ott 2007, 12:59:24 »
Ciao a tutti .
Vi sarei molto grato se riusciste a farmi capire come, nel mission builder di 1946 v.4.08,si possano "sollevare" gli oggetti statici da terra.
Ho cercato di copiare alcune cose anche dalle missioni di I16 cup....dove molte luci oggetti sono per aria,poi però nel file .mis non sono riuscito a  capire quale parametro nella stringa va' cambiato...
Grazie in anticipo.
Ybor
Re: mission builder help
« Risposta #1 il: 05 Ott 2007, 18:06:42 »
Du iù spic inglisc, mai bro ???
Raising and Lowering Objects in the FMB (Article #386 Page 1)
RAISING AND LOWERING OBJECTS IN THE FMB
To raise/lower objects (lights and smokes) here is what you need do:
1. Place the object on the map. (Left click mouse and press Ctrl)
2. Select the object (Left click mouse) and go into 3D mode.(Press Enter while close enough to see terrain details).
3. Hold left click and press F4. (If you don't do it in that order the next function will not work)
4. While holding the left mouse button move mouse away from you to raise, pull towards you to lower.
5. To move object on the horizontal plane release F4, hold down the left mouse button and move mouse.
6. Bonus Tips:
Bonus Tip #1. Once you have the object at the same height you can place additional lights/smoke at that same level by pressing "Insert".
Bonus Tip #2. Using "Insert" will work with any object you want to replicate)
Super Bonus Tip. Once you place any "Object" you can press "Page Up/Down" to scroll through the object list and see the object on the map. (This ONLY works with "Objects" List)
« Risposta #2 il: 05 Ott 2007, 19:47:02 »
ahhhh my bro...my bad english...ill growin'up :lol:
THX
 :mrgreen:
