Autore aviation humour....... mica tanto....  (Letto 1716 volte)
« il: 18 Lug 2007, 16:57:57 »
vi posto qualche comunicazione tra piloti e torri un po' fuori dal comune....
questa è quella che preferisco:
ATC: "N123YZ, say altitude."
N123YZ: "ALTITUDE!"
ATC: "N123YZ, say airspeed."
N123YZ: "AIRSPEED!"
ATC: "N123YZ, say cancel IFR."
N123YZ: "Eight thousand feet, one hundred fifty knots indicated."
Poi....
Controller: "USA353 (sic) contact Cleveland Center 135.60.
(pause)
Controller: "USA353 contact Cleveland Center 135.60!"
(pause)
Controller: "USA353 you're just like my wife you never listen!"
Pilot: "Center, this is USA553, maybe if you called her by the right name you'd get a better response!"
Pilot: "Approach, Acme Flt 202, with you at 12,000' and 40 DME."
Approach: "Acme 202, cross 30 DME at and maintain 8000'."
Pilot: "Approach, 202's unable that descent rate."
Approach: "What's the matter 202? Don't you have speed brakes?"
Pilot: "Yup. But they're for my mistakes. Not yours."
Beech Baron: Uh, ATC, verify you want me to taxi in front of the 747.
ATC: Yeah, it's OK. He's not hungry.
Cessna 152: "Flight Level Three Thousand, Seven Hundred"
Controller: "Roger, contact Houston Space Center"
questa è fantastica:
O'Hare Approach:  USA212, cleared ILS runway 32L approach, maintain speed 250 knots.
USA212:  Roger approach,  how long do you need me to maintain that speed?
O'Hare Approach:  All the way to the gate if you can.
USA212:  Ah, OK, but you better warn ground control.
7MA: Cessna 187MA is 5 NE, landing, with the numbers.
HYA: Roger 7MA, make straight-in runway 22. Say type landing.
7MA: We're a Cessna 182.
HYA: Negative, say *type* landing.
7MA: Uh, 7MA is a Cessna 182 slant Uniform.
HYA: 7MA, I say again, say **type** landing.
7MA: (Silence) A good one I hope.
ATC:  Alitalia 345 continue taxi holding position 26 South via Tango check for workers along taxiway
AZA: Ali345 Taxi 26 Left a via Tango. Workers checked - all are working
e ora, per finire....
Washington D.C., Clearance Delivery: "GAF269, you are cleared to destination Indian Springs via after take off radar vectors to 4000 feet thereafter present position direct BOM do not pass BOM at 6000 feet or below after passing 15000 feet turn right on heading 280 to intercept J156 direct ZZT thereafter intercept J158 own navigation read back."
GAF 269: "Roger German Air Force 269 is cleared to Destination Indian Springs via after take off radar vectors to 4000 feet thereafter present position direct BOM do not pass BOM at 6000 feet or below after passing 15000 feet turn right on heading 280 to intercept J156 direct ZZT thereafter intercept J158 own navigation and I need another pencil."
                                          Buon Volo...
        Alessandro
Re: aviation humour....... mica tanto....
« Risposta #1 il: 12 Ago 2007, 17:35:45 »
Questa è accaduta veramente quando dopo un lungo sciopero ad oltranza Regan licenziò i controllori degli aeroporti internazionali americani sostituendoli con quelli degli aeroporti locali del centro america. I nuovi arrivati pur conoscendo il mestiere parlavano uno slang incomprensibile.
O'Hare approach-British 325 from O'Hare approach proceed via 35&%_--""£=prr to =)(??££""...(incomprensibile)
British 325- Sorry O'Hare I don't understand say again
British 325- Sorry O'Hare I don't understand say again and slowly
British 325- Sorry O'Hare I'm not able to understand you
O'Hare approach-British 325 do you speak English ?
British 325- O Yes sir I do speak English but I don't understand Yankee
« Risposta #2 il: 12 Ago 2007, 17:54:19 »
Questa invece è successa tanti anni fa quando l'ATI consociata dell'Alitalia per le linee nazionali aveva solo Foker 27. Il fatto che questi aerei fossero piccoli aggiunto al fatto che la sede dell'Ati era a Napoli e quindi molti suoi piloti erano del Sud e di bassa statura aveva procurato ai Piloti Ati il soprannome di Bassotti.
Il controllo di Roma chiama un aereo Ati
Ati 123 Roma radar avete un traffico ad ore 12 più basso di Voi
attimo di silenzio e poi un' anonimo disse in frequenza:
Più basso dell'ATI non è possibile
Ero in volo su un DC9-30 atterrammo a Linate andammo al bar a prendere un caffè tornammo a bordo per la tratta successiva e vi giuro che stavamo ancora ridendo....
