Autore 4.09?  (Letto 2600 volte)
Offline Cymao
  • Post: 1615
4.09?
« il: 27 Dic 2007, 14:35:53 »
Sto al lavoro ma mi è arrivato sto link per scaricare la 4.09
http://hosted.filefront.com/MaXMhZ
Boh già circola su HL, provatela voi tanto io sto col Joy che non funge e fatemi sapere.
Scaricabile anche dal forum della 1C
http://forum.1cpublishing.eu/showthread.php?t=2462
« Ultima modifica: 27 Dic 2007, 14:50:57 da cymao »
Offline Gianpaolo
  • Post: 419
Re: 4.09?
« Risposta #1 il: 27 Dic 2007, 16:54:16 »
oppure : http://hosted.filefront.com/MaXMhZ
http://www.mission4today.com/index.php?name=Downloads&file=details&id=3199
questo è quello che cambia:
* New maps:
Bessarabia
Iasi (online)
Odessa (online)
MTO
Slovakia
Slovakia (online)
* New default skins for planes
409b1m.zip contains maps only.
If you want to install replacement skins then download
409b1m_skins.zip and install over the map pack.
fb_3do20.sfs from the map pack have to be overwritten.
***** CHANGES in GRAPHICS ***********************
* Increased buffer size for stationary objects (buildings etc.)
to prevent freezes under some circumstances.
* Colors of water corrected for Water=2,3,4 modes.
Now when looking down it is no more black/dark blue.
* Optimized Shaders for Nvidia 8X00 series video cards.
* Added a new mode for increased visibility distance.
Visibility increased from 36 km to 72km
under "Clear" and "Good" weather conditions.
Note: This mode is not optimized for performance
(freezes and low fps are possible on low-end systems)
This mode is recommended for fast CPUs & powerful video
cards such as Nvidia 8800 series, ATI X1800 series or better.
With 512 MB of video RAM.
This new feature is available only in "Perfect" game graphics mode.
Also, there is a possibility to have problems with clouds and their
shadows at far distances, due to some engine limitations.
Modify your conf.ini string in the [Render_OpenGL] section
to use this mode:
LandGeom=3 (new mode is ON)
LandGeom=2 (back to normal mode).
in + speriamo blocchi lo scempio delle mod!!! =D>
« Ultima modifica: 27 Dic 2007, 17:08:35 da Gianpaolo »
nella vita o c'hai c.u.l.o....o te lo fanno!!! check 6 & Live to fight another day!!!
Re: 4.09?
« Risposta #2 il: 27 Dic 2007, 17:11:57 »
Nuovi aerei no... peccato
cmq se viene installata si installa solo in modo permanente??
nn c'è un sistema x attivarla e disattivarla ogni volta??? ;) ;)
Offline Er Kometa
  • I.JG53
  • Post: 232
  • Pik As Geschwader
Re: 4.09?
« Risposta #3 il: 27 Dic 2007, 19:20:01 »
Salvati il vecchi file .exe e .sfs da qualche parte
Io prendo il G-6... (frase detta in una missione in Italia dove si potevano usare i 109 G-6 base o i 205, gli avversari erano tutti Spit Mk.IX)
Offline jomissuri
  • Post: 411
Re: 4.09?
« Risposta #4 il: 27 Dic 2007, 19:31:33 »
ragazzi io ho scaricato tutto...sia le skin che le mix.
Posso usarle con il mod enabler?
se si, mi dite come fare?
GRAZIE
SIAMO TUTTI UGUALI....PRIMA DI STACCARE L'AUTOPILOTA!!! SOLO STACCANDOLO POTRAI SAPERE CHI SEI VERAMENTE!!!
Offline Er Kometa
  • I.JG53
  • Post: 232
  • Pik As Geschwader
Re: 4.09?
« Risposta #5 il: 27 Dic 2007, 19:52:07 »
ah, non ne ho idea. Però se la patch va senza i mod prova ad ativarli, così vedo se installare la beta o aspettare la versione definitiva...
Re: 4.09?
« Risposta #6 il: 28 Dic 2007, 11:20:20 »
Io faccio così.... x adesso nn se ne parla, poi quando sarà obbligatorio avere la patch x giocare on-line ci sarà il passaggio... ;) ;)
Offline Ramaja
  • Post: 109
Re: 4.09?
« Risposta #7 il: 04 Gen 2008, 13:17:08 »
Ieri ho provato per la prima volta la 4.09.
Non saprei ma sono abbastanza convinto che qualcosa sia cambiato nel 109G2: per esempio adesso in rullaggio è più sensibile ai comandi e tende a derapare come un He-111 se non si blocca lo ruotino.
Mi da anche la sensazione che salga decisamente meglio rispetto a prima, ma non sono un esperto di G2 quindi è solo una sensazione...
Re: 4.09?
« Risposta #8 il: 14 Apr 2008, 12:34:02 »
GRAZIE
io ho seguito queste istruzioni: http://forums-it.ubi.com/eve/forums/a/tpc/f/851105185/m/2751023336
SimplePortal 2.3.7 © 2008-2025, SimplePortal
