Autore Decolli ed Appontaggi con Hercules C-130 !!!  (Letto 1361 volte)
Offline marius7475
  • Post: 157
  • semper fidelis
« il: 17 Lug 2008, 11:00:57 »
Carlo, ti ricordi quella volta che su FSX abbiamo provato, oltre che con il Ceesna di def, ad appontare su portaerei con un velivolo più pesante??? Il C-130 lo fa davvero!!!  34.274 kg di pura potenza! Ho sempre amato questo aereo... per settembre inizio un modello 1/48... troppo forte... ci fanno anche un touch - and - go (3° minuto) !!!  [yahoo] [plane] [yahoo]
« Ultima modifica: 17 Lug 2008, 11:08:34 da marius7475 »
marius7475
-semper fidelis-
Offline marius7475
  • Post: 157
  • semper fidelis
Re: Decolli ed Appontaggi con Hercules C-130 !!!
« Risposta #1 il: 17 Lug 2008, 14:01:19 »
questo gigantesco B-52 poi...
This is not photoshopped. It happened in early 1990 in the Persian Gulf, while U.S. carriers and B-52s were holding joint exercises. Two B-52s called the carrier (USS Ranger) and asked if they could do a fly-by, and the carrier air controller said yes. When the B-52s reported they were 9 kilometers out, the carrier controller said he didn't see them. The B-52s told the carrier folks to look down. The paint job on the B-52 made it hard to see from above, but as it got closer, the sailors could make it out, and the water the B-52 jets were causing to spray out. It's very, very rare for a USAF aircraft to do a fly-by below the flight deck of a carrier. But B-52s had been practicing low level flights for years, to come in under Soviet radar. In this case, the B-52 pilots asked the carrier controller if they would like the bombers come around again. The carrier guys said yes, and a lot more sailors had their cameras out this time.
« Ultima modifica: 08 Ago 2011, 14:55:37 da Ripley »
marius7475
-semper fidelis-
« Risposta #2 il: 18 Lug 2008, 11:39:48 »
Mitico C130
In fondo basta applicare all'aereo l'attacco per la catapulta ed il gancio per i cavi di frenata e qualunque mezzo può decollare ed atterrare su una portaerei.  Mi piacerebbe provare con una Panda !!!
Guardando l'esperimento dal ponte però
 :mrgreen:
