Autore Dual Core & Seven, la soluzione arriva dagli utenti  (Letto 10058 volte)
« il: 23 Gen 2011, 11:12:17 »
Ecco la prima e concreta soluzione al problema rilevato dagli utenti di Dual Core e utilizzatori di Window Zeven:
Citazione da: FlyingHigh
I hav a lot of stutters and freezes with RoF on my system.
(WIn 7 x64 & Core 2 Duo)
FPS was:
Min/Max/Avg : 7 / 41 / 22.596
I wrote a small utility that rebalance processors usage by rof.exe.
Now fps is:
Min/Max/Avg: 33 / 44 / 37.928
and it rather smooth and playable.
I test it on two systems with Win7 x64 Core 2 Duo.
After same tweak for my second win7 x64 dual core system avg fps is x3 times better now (13 -> 40).
May be it helps smbd else.
I dont think it helps for dual core configurations with other OS or quad core processors , but you can try.
Quick start:
1) run RoFBoost.exe (as Administrator or disable UAC).
2) start RoF.exe
3) Load any mission (quick, single, career, multi)
4)
 - Find RoFBoost icon in system tray, do right mouse click, select "Affinity Core 1"
 - switch back to game and check performance
 - If it doesnt help(!) and perfromance is still poor - select "Affinity Core 2"
5) If there is no difference in performance after tweak - it means you have some other bottleneck in system performance.
UPDATE: 2011-01-19
It doesnt affect your hardware.
It just tell main rof.exe thread use one of two cores as "ideal core" during scheduling process.
You can do the same thing using Process Hacker program, but rof_boost tool is more easy to use and more user friendly.
Actually I tested it for Win 2003 Dual core configuration yesterady and got some performance and smooth improvment too. Not so significant as for Win 7, but rather noticeable.
It would be nice if somebody post results after using this tweak for different OS`es and cores.
UPDATE: 2011-01-22
Success stories:
PP_Nobody96 Re: Should this-WIn 7 x64 & Core 2 Duo tweak- get more atten
DukeNukem Re: Should this-WIn 7 x64 & Core 2 Duo tweak- get more atten
Allegato:
rof_boost.zip
:clapping: :clapping: :clapping:
Re: Dual Core & Seven, la soluzione arriva dagli utenti
« Risposta #1 il: 23 Gen 2011, 11:21:46 »
Invito i possessori di questo magnifico sim che frustrati dai problemi legati al processore a provarlo e riportare l'effettiva risoluzione del problema :wink:
