Autore Beta tester e prime impressioni su CoD  (Letto 6214 volte)
Offline 4Stormo_Nero
  • Post: 254
« il: 08 Feb 2011, 13:35:01 »
Queste le prime impressioni su CoD riferite da un beta tester:
Some features:
- "Press I button" doesnt start engine with "complex engine management on". Rotation starts and then stops very soon
- Bf-109 tends to roll during takeoff, no heavy yaw movements as in il2
- There is no runway as in IL2, there is just flat field surronded by hangars and other buildings. You can takeoff in any direction.
- lots of details on airfield makes it much easier to take of and landing as you feel speed better
- he was amazed with low altitude flight. Its feel of speed is much improved compared to IL2. Main thing is there is no flat surfaces. Whole ground is non flat, and his first thought was "how can I do emergency landing here?" He wasnt able to find any flat and big enough area.
- contacts visibility is very good if they are on same level as you. If you are above them you lost them immediately. Sea is very noisy because of waves and you cant see enemies. If contacts are above you they are blended with sky and its hard to find them again.
- on a high G (he did vertical loop) heads tends to move down and sight (aiming device) goes up on your screen, you have to correct your view direction.
- you need to turn on sight illumination, otherwise its hard to use it. Cabin lighting is amazing.
- bots behaviour is very diffrerent from IL2. He knows Il2 bots very well , but he wasnt able to shot down any one. They lowered from 4 km to sea level and still no one was heavily damaged
- he wasnt able to hit a spitfire with cannons, very very hard to aim. Guns fire slightly unsynchronously and BF-109 starts to yaw right and left. Hard to continue to fire for more than 2-4 rounds.
- even slight roll without proper work with pedals make airplane to slide and its your tracers start to drift away from sight center.
- smoke tracers are very very beautifull
- sound is amazing, huge "BAANG" on every cannon shot
- Airplane is very sluggish, stalls start immediately without any pre-stall shake
- on low speed airplane doesnt react on you controll. It seems that stall fighting is not possible anymore
- he wasnt able to hear spitfire on his 6. Once he saw a tracers he immediately did roll and jump into clouds
- once he jumped into clouds all windows become misted. When he goes from cloud it was hard to tell where is sky and where is ground, he had to wait some time whiled windows became unmisted
- he approached 2 spitfires on his way back. He missed in his first attack then he went up and after that he lost spitifires. He flew in that aread for a while but wasnt able to find them.
- airfield visibility on a shore is very good: big field surrounded with buildings
- use flaps you have to press "F" once and then hold it again until you satisfied with flaps angle
- he pressed "G"once to extend landing gear, but as it appeared later he failed with that
- there was no speed bar or other text on screen, neither for flaps nor for gears
- he landed without gears. Propeller was damaged and airplane was covered with cloud of dust once he stopped to slide
- after mission stats showed the Do-215 was shot down, 2 spitfires and one Bf-109. He had 3% fire accuracy for 1 spitfire and deliver 10% damage to him.
- His Bf-109 had 15% damage. There are no details how much of that damage came from enemies and how much from his langing or other wrong actions
- In "zoom view" you cant pan too much, just +- 20 degrees (maybe +- 30)
 :good: :good: :good:
Re: Beta tester e prime impressioni su CoD
« Risposta #1 il: 08 Feb 2011, 17:56:52 »
Tutte cose carine quasi al 100%, ma questa dei vetri appannati mi piace proprio!
Offline Gianpaolo
  • Post: 419
« Risposta #3 il: 08 Feb 2011, 20:21:52 »
peccato che non sia realistico salvo il caso di nubi temporalesche e dubito che si tratti di tale tipo(anche perché non conviene entrare)...
Offline piero_tasso
  • Post: 30
« Risposta #4 il: 08 Feb 2011, 20:58:39 »
Citazione da: Ilya Shevchenko
The Italian Fiat G.50 is an embarrassment in a dogfight
  :sarcastic:
Nel filmato ad un certo punto si vede un cursore: il cockpit sarà cliccabile?
Citazione da: Oleg, parlando dei successivi capitoli...
I can’t tell you the exact area or name of the title yet (market factors will have a say) but I personally prefer the Med.
speriamo!
Intanto metto da parte i soldi per un pc nuovo...
un tasso ai comandi, fino a 15 nuovi tipi di schianto al suolo!
« Risposta #5 il: 08 Feb 2011, 21:01:51 »
peccato che non sia realistico...
Lo supponevo!
...All in a good way of course...
Non mi piace il mare del 3° screen. Da quell'altezza (guardate le case) non si dovrebbero vedere tutte quelle onde...
« Ultima modifica: 08 Feb 2011, 21:41:18 da Ripley »
Offline Gianpaolo
  • Post: 419
« Risposta #6 il: 08 Feb 2011, 21:58:01 »
Ti confermo, o è uno tsunami o è esagerato...
« Risposta #7 il: 09 Feb 2011, 09:31:30 »
...peccato che non sia realistico....
Stavo ripensando...non potrebbe essere che la tua esperienza sul Tornado ti porti a dire così (e ci credo ciecamente), ma che la diversa velocità degli aerei dell'epoca, e le diverse condizioni climatiche di umidità, facessero comunque appannare i parabrezza?
Mi pare strano che azzardino una cosa "inventata", tanto per cedere alla tentazione dell'effetto facile...si saranno documentati con veri piloti veterani, o stiamo lentamente scivolando nell'arcade?
Offline Drust
  • Post: 609
    • proteggiamo l'ambiente
« Risposta #8 il: 09 Feb 2011, 11:34:54 »
domanda:
può essere il fatto che la cabina del tornado sia diversamente pressurizzata dalla cabina di un bf109 ???
Offline Lupo
  • Post: 185
« Risposta #9 il: 09 Feb 2011, 13:13:48 »
questione di aerodinamica.
  • Post: 254
« Risposta #10 il: 09 Feb 2011, 13:14:48 »
Ad eccezione delle versioni G5 e G8 il 109 non aveva la cabina pressurizzata.
Offline Drust
  • Post: 609
« Risposta #11 il: 09 Feb 2011, 16:17:11 »
informato come sempre quando si tratta di aerei, carri... o donne meridionali :sarcastic:...
(gli altri lo sanno che le ragazze più belle d'italia si trovano nella provincia di salerno?! :dance1:)
beh comunque io penso che possa essere dovuto alla cabina pressurizzata o meno...
ci penso un po', o si faccia avanti chi ha già la risposta scientifica
Offline Drust
  • Post: 609
« Risposta #12 il: 09 Feb 2011, 16:46:20 »
oppure tralasciando la pressurizzazione della cabina, l'appannaggio di cui parla il beta tester, non avviene all'interno, ma all'esterno dei vetri.
è risaputo che le nuvole sono un sistema termodinamico instabile e che quando un aereo le attraversa, il vapore d'acqua condensa in goccioline d'aqua, specie sulle ali (che in quota sono fredde, e perciò si ha la condensazione).
(lo potete vedere anche in RISE OF FLIGHT quando attraversando una nube, si formano gocce d'acqua sugli occhiali)
ora se si è molto in quota e magari è inverno, fa molto freddo e l'acqua può diventare ghiaccio modificando la forma delle ali, facendo precipitare l'aereo se non si interviene prontamente (sistemi de-icing, rompono o sciolgono il ghiaccio)
ritornando all'osservazione di Gianpaolo, può darsi (molto probabile) che i vetri della cabina del tornado  siano munti di sistemi anti-icing (prevengono la formazione del ghiaccio) e perciò non avviene nessun fenomeno di condensazione
« Risposta #13 il: 09 Feb 2011, 17:04:07 »
Scusate se mio intrometto visto che non so quasi nulla di aerei militari, ma per gli aerei civili posso dire che l'appannamento non esiste. I parabrezza di un aereo sono riscaldati SEMPRE perché il vetro a basse temperature (a 35.000 ft l'aria standard è a 50° sotto zero) diventa talmente fragile che basterebbe impattare un passerotto per mandarlo in frantumi. E ovvio quindi che esternamente non si appanna visto che è riscaldato, e non si appanna neppure internamente non solo per il calore ma soprattutto perché l'aria pressurizzata all'interno dell'aereo è completamente priva di umidità, infatti si consiglia durante i voli commerciali di bere più acqua che si può.
Offline Gianpaolo
  • Post: 419
« Risposta #14 il: 09 Feb 2011, 18:16:56 »
non dipende dall'aerodinamica ma unicamente dal tipo di nube...
(per condensa intendo quelle esterna all'abitacolo non quella interna)
Digitate su youtube e vedete ;)
di fatto non è sbagliato mettere l'effetto goccia nel gioco ma l'importate è che non sia per tutte le nubi...
