Autore @LG - PROBLEMI in TS  (Letto 1978 volte)
Offline 68tf_Revan
  • Post: 1
« il: 11 Lug 2011, 21:23:53 »
sono costantemente bannato dal TS di gruppo (sette volte di fila a intervalli irregolari, prima time ora permaban) da una sconosciuta entità...
mai capitato prima...
...e il sito qua non mi fa aprire i profili utenti, altrimenti avrei MPato
AIUTO!
<19:45:13> ‎"serveradmin from 174.37.17.115:37192‎"‎
: InstantTeamSpeak.co m: Deleting ban 6971
<19:45:22> ‎"serveradmin from 174.37.17.115:37364‎"‎
: InstantTeamSpeak.co m: Adding Ban 87.7.57.213
<19:45:23> You were banned permanently from the server by ‎"serveradmin from
174.37.17.115:37364‎"‎ (None)
<19:45:23> Disconnected from server
<19:40:10> Trying to connect to server on 78.159.107.117:4282
<19:40:10> Connected to Server: ‎‪ITAF & FRIENDS‎‬‎
<19:40:10> Provided by http://www.InstantTeamSpeak.com, for help goto
http://www.InstantTeamSpeak.com/teamspeak-server-support.php
<19:40:10> Powered by tuttovola.org >>>Supportaci con una donazione<<<
<19:40:13> You switched from channel ‎"Hall‎"‎ to ‎"Pause‎"‎
<19:40:13> Channel group "Guest (869)" was assigned to ‎"‎‪TF_Revan‎‬‎‎"‎ by ‎‪ITAF & FRIENDS‎‬‎.
: InstantTeamSpeak.co m: Adding Ban 87.****.213
<19:53:39> Trying to connect to server on 78.159.107.117:4282
<19:53:39> You are banned permanently. Reason: "None"
<21:11:42>
‎"serveradmin from 174.37.17.115:51763‎"‎
InstantTeamSpeak.co m: Adding Ban 87.**.22.195
<21:11:43>
You were banned permanently from the server by ‎"serveradmin from 174.37.17.115:51763‎"‎
(None)
<21:11:43>
« Ultima modifica: 11 Lug 2011, 22:18:10 da 68tf_Revan »
Offline AirBone
  • Post: 135
Re: @LG - PROBLEMI in TS
« Risposta #1 il: 11 Lug 2011, 23:07:55 »
Sono appena arrivato, non funge anche a me!!!! nessuno sa' nulla?!?
SALUTI.
Offline AirBone
  • Post: 135
« Risposta #2 il: 11 Lug 2011, 23:17:15 »
va beh, il canale itaf non va' :( io sono entrato in Team speak pubblic, nel canale italian talk, se qualcuno vuole accomodarsi sono li' xD, ho creato un canale temporaneo chiamato itaf, la pass e' ITAF XD
vi aspetto per un po' qua...
« Ultima modifica: 11 Lug 2011, 23:22:35 da AirBone »
Offline AirBone
  • Post: 135
« Risposta #3 il: 11 Lug 2011, 23:55:20 »
allora , io ho fatto cosi':
1) clicca su Bookmarks
2) teamspeak public (nel caso non abbiate nessun public server, usate questo address:  voice.teamspeak.com)
3) cerca il canale itaf (verso la fine della lista) la pass e' :ITAF
« Ultima modifica: 12 Lug 2011, 00:09:36 da AirBone »
« Risposta #4 il: 12 Lug 2011, 16:46:24 »
ben fatto Daniele!
ora sembra tutto ok
