Autore XIII Campagna TAW  (Letto 3757 volte)
XIII Campagna TAW
« il: 13 Apr 2018, 19:10:28 »
banner TAW.jpgXIII Campagna TAW
New TAW campaign starts 15.04.2018 on Sunday morning. Registration is open.
Ho già provveduto a registrare la squadra LINK appena vi registrate come piloti fatemi sapere postando qui che vi aggiungo.
Changes and new features
Scenario based maps. On some maps Axis attacks so they have more limits (aircraft, tanks, pilots) and their tanks convoys spawn more frequent for the first several missions and on other maps Allied attacks so they have advantage. There also maps with draw situation. List of maps:
#1 Moscow_North – Axis offensive
#2 Moscow_South – draw
#3 Moscow_North – Allied counteroffensive
#4 Stalingrad_Center – Axis offensive
#5 Stalingrad_South – draw
#6 Kuban - Axis offensive
#7 Stalingrad_Center - Allied counteroffensive
#8 Kuban - Allied counteroffensive
The frequency of spawning tank convoys depends on three factors:
Map scenario – more frequent for one side for first several missions
Depot destruction – the more damage/destroyed the less frequent tanks spawn
Captured area – the more captured cities the more frequent tanks spawn
French version of the website thanks to -IRRE- team / Les IRREductibles  www.lesirreductible s.com
Pilot gets CM if he ditches on a friendly airfield with any AK or GK.
Pilot gets new aircraft after 3 CM if his hangar is not full. Before pilot got new aircraft after sortie ended with CM. Now if pilot has 3/3CM and lost an aircraft he gets a new one.
New layouts of airfields. There are less buildings and more planes than before.
After capturing a city a train and supply convoy is send to this city in the next mission.
An enemy airfield is not repaired in current mission if it was attacked in previous mission. It doesn’t concern border airfields.
Airfields supply are also damaged after attacking and destroying airfield facilities. Airfields supply are also damaged by tanks convoys.
Buildings and hangars are generated on non-frontline airfields, but it shouldn’t be attacked because it will not be counted (to save cpu they are not in the log files). As before only frontline airfields should be attacked. There is text “Attack!” under it on the map in game.
After land of every 12 paratroopers there is a text message that inform how many paratroopers landed near enemy airfield from the beginning of the mission.
Gelenzik airfield fixed. Take off is towards sea not the mountain.
Bug with different mission ID on the www page fixed.
Convoys detect big rivers so they are not generated on it.
Bigger Moscow_South map (work in progress)
In mission list on the webpage there is description of the events after each mission. You may find there info about what was attack and destroyed, how airfields was damaged and supplied etc. It’s only in English version for now.
The manual has been updated. If something is unclear or is missing let me know.
Plane set as before (missing BOK planes added). Please check manual.
Attenction!
To fly transport mission choose bomber with text “transport” and take no bombs/rockets (it’s necessary after 3.001 update). It doesn’t concern Ju-52.
If payload are locked then you have to choose airfield and aircraft several times. It’s a bug after 3.001 update.
If you see black screen after connection to the server please wait for a while.
Good luck!
fonte: https://forum.il2sturmovik.com/topic/21029-tactical-air-war/?do=findComment&comment=604859
Offline Cymao
  • Post: 1626
Re:XIII Campagna TAW
« Risposta #1 il: 14 Apr 2018, 12:01:06 »
Fatto!
« Risposta #2 il: 14 Apr 2018, 13:04:31 »
Aggiunto, e visto che c'era o aggiunto pure Gianpx  :mda:
Offline Febaba
  • Post: 743
  • manovra "febabas"
« Risposta #3 il: 15 Apr 2018, 00:50:19 »
fatto, comandi!
Offline Centauro
  • Post: 26
« Risposta #4 il: 16 Apr 2018, 01:01:06 »
registrato anche io =)
« Risposta #5 il: 17 Apr 2018, 23:30:54 »
Aggiunti!
Offline Rani
  • Post: 1987
  • Cave Canidem !!!
« Risposta #6 il: 11 Mag 2018, 14:04:35 »
Ciao Gigi mi sono inscritto, puoi aggiungermi !!
Sempre a testa alta !!
« Risposta #7 il: 13 Mag 2018, 21:42:28 »
 :good:
... anche se è praticamente finita, mi pare che sia l'ultima mappa.
« Risposta #8 il: 16 Mag 2018, 21:03:54 »
Campagna terminata, ci abbiamo volato poco e per nulla organizzati. Pessima cosa.  :mda:
Offline Rani
  • Post: 1987
  • Cave Canidem !!!
« Risposta #9 il: 17 Mag 2018, 13:18:43 »
Proporrei delle pene corporali... :spiteful:
Offline Rani
  • Post: 1987
  • Cave Canidem !!!
« Risposta #10 il: 18 Mag 2018, 15:00:30 »
Io proporrei di allenarci tutti un po di piu'.
Utilizziamo il server finnish per fare pratica.
Cerchiamo  cosi di essere piu' operativi alla prossima edizione della TAW. ciao
